Will not crank
JONATHAN82
  • 1988 DODGE RAM
  • 100,000 MILES
Truck made no noise when turned key. Tried to jump off didn't work, so put charger on it. Got it to try to over and then make clicking noise. Please any help would be appreciated. Thanks
Wednesday, June 12th, 2019 AT 8:44 PM
  • 109,755 POSTS
Welcome to 2CarPros.
A clicking noise usually indicates a bad battery. I'm going to walk you through some simple steps. Follow them in the order I provide.
First, we need to do a simple load test on the battery. Follow this link.
Now if the battery passes that test, the next thing I need you to do is confirm the battery cables are clean and tight. The starter places a heavy load on the battery, and even though it passes a load test, a weak connection can cause it to fail.
Here is a link that explains how to clean and tighten and the symptoms related to them being in poor condition:
Once we are sure the battery is good, fully charged, the terminals are clean and tight, and so on, if the starter still only clicks, make sure the main ground between the battery to the engine block is clean and tight, free of corrosion.
I have to be honest, based in your description, I think the battery is bad. If you could, I would remove it and have it load tested at a parts store. They can tell exactly how many cranking amps the battery has left in it and if it needs replaced. The aforementioned test will help if the battery is very weak. Here is a link that explains how to replace one. I am providing them in case you decide to remove it to have it checked.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Try these things and let me know what you find. Please feel free to ask questions or let me know if you need help.
Wednesday, June 12th, 2019 AT 9:22 PM
JONATHAN82
Okay, I'll definitely do all that. Thanks for such a quick response. I've got to pull a four day weekend and I work twelve hour days so I'm not going to be able to get around to it until Monday hopefully. I'm going to use my dad's truck until then. Thanks again for the advice I'll let you know how it goes.
Wednesday, June 12th, 2019 AT 9:50 PM
  • 109,755 POSTS
Welcome back:
Not a problem. I just hope it helps. I will watch for your results.
Wednesday, June 12th, 2019 AT 10:59 PM
JONATHAN82
Hey, I put my battery on there charger last night and tried it this morning. It cranked up for me so it was just a completely dead battery.I took it to get checked at auto zone like you said begin before I charged it. Thank you very much for your help.
Friday, June 21st, 2019 AT 2:05 PM
  • 109,755 POSTS
Welcome back:
You are very welcome. I'm glad it was a simple fix. If you find it goes dead again, let me know and we'll check the alternator. It's easy to do.
Friday, June 21st, 2019 AT 9:25 PM
