Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Xterra
Engine
Symptoms
Not Cranking Over
Engine will not crank
2005 NISSAN XTERRA
121,000 MILES • 6 CYL • AUTOMATIC
RAY2COOL
MEMBER
New starter, new battery. Radio, A/C and interior lights work. have checked all fuses and they are good.
Nov 9, 2020 at 1:17 PM
Experienced Mechanic
Good morning,
I attached the wiring diagram for the starting system.
You need to go to the starter relay and do some testing. You will need a voltmeter to check to see if the proper voltages are at the relay.
Images (Click to enlarge)
Nov 9, 2020 at 5:45 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
