I would try to crank the engine over while the car is in neutral because you may have a gear range sensor that is out. Also, there are 3 fuses that run the system I would check. here is a guide to help with that and I have included the starter wiring diagrams so you can see how the system works and which fuses to check.
Here are the fuse locations as well.
This guide can help us fix it as well:
Images (Click to enlarge)
Apr 5, 2023 at 7:13 AM
