Will not crank Spark plugs were replaced?
200,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
NATS787
Last October the fuel pump went out. I bought one from eBay and a friend of mine who's a certified mechanic put it on. Immediately the fuel efficiency was worse, and it would barely accelerate up a hill. Then a couple months later the check engine light came on. I can't remember the exact codes but nothing major. Spark plugs were replaced and something else I can't remember. A couple weeks ago it wouldn't shift into fourth gear. Mechanic friend of whom I don't think I can trust anymore and shouldn't have ever trusted said that it was in limp mode. It seems to come out of limp mode after it's drove for a little while and drives fine except for the same acceleration issue. I was told to get a MAF sensor but then told that it wasn't the issue even though I was under the impression that it was the code thrown. Now it acts as if it's out of gas but it's not. Fuel pump issues again apparently.
Jul 22, 2025 at 7:35 AM
NATS787
Wait I found the paper that has the code on it for the check engine light. Maybe it was major, and I was told wrong. It says an engine misfire. I don't know what to do. I'm a single mom and work as a Medical Courier so I need my car. I've been screwed around by the person I trusted to help me with this. Any advice or help is greatly appreciated.
Jul 22, 2025 at 10:13 AM
CANNON1349
  • 861 POSTS
Hello, fuel and air issues can cause similar symptoms while driving. Less air = less fuel command from the pump and of course less fuel will give the same acceleration issues. Perhaps we can assume the fuel pump was installed correctly yet diagnosed incorrectly. A bad MAF will cause acceleration issues, but typically there will be a code but this could be verified with a scan tool that can read live data. The first thing I would do is to check that all the intake/air hoses are intact and without tears/holes in them. Sometimes a simple vacuum hose unplugged can give this condition.
William
Jul 22, 2025 at 12:34 PM
NATS787
Okay, thank you so much.
Jul 22, 2025 at 2:27 PM
CANNON1349
  • 861 POSTS
No problem, please let us know how it goes. I can try to help if you have any further information.
William
Jul 23, 2025 at 11:28 AM
