Alternator does not charge the battery?
180,000 MILES • 1.5L • 2WD • MANUAL
TRINAGIRL82
I have replaced the alternator, battery, and the fuses, but it still won't charge my battery and the belt is almost new. What to do now?
Jul 15, 2022 at 3:58 AM
  • 110,251 POSTS
If you go to the alternator, check to see if the white wire with a red tracer has power and the solid red wire does as well. According to the wiring schematic for the charging system, these two wires receive power directly from the battery. So, they should have B+ at all times.
I attached the wiring schematic below for you to reference. Here is a link you may find helpful when checking the wiring:
Let me know what you find. Additionally, pic 3 shows the locations of the fusible links in the under-hood fuse box.
Take care and let me know if you have other questions.
Jul 15, 2022 at 3:21 PM
