Wondering if this is a free spin engine or not
JIMSAUTO
  • 16 POSTS
Getting ready to replace the timing chain on a 2003 Mini Cooper S with the 1.6l SOHC supercharged engine. The old chain broke while car was being driven and I'm trying to find out whether or not this is an interference engine or a free spin engine.
Oct 15, 2013 at 9:00 AM
MADMIKE1735
  • 951 POSTS
yes, this is an interference engine.... i would recommend pulling valve cover, and performing a cylinder leak down test, as you cannot perform a compression test without the chain.... (your pulling the v/c cover so you can verify both valves are closed in the cylinder being tested)
Oct 15, 2013 at 11:24 AM
