Won't stay running after minor front collision
136,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
BABYHUEY42379
Had minor front collision. Service airbag light is on. Will start and run decent then just shuts off after about 5-10 seconds
Feb 5, 2016 at 7:51 AM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online then have a pro scan for codes.
Feb 5, 2016 at 8:45 AM
BABYHUEY42379
I'll try that. I've ran scan got a PO449. Comes back as emmisions sensor. But that code was there a year ago. No other codes.Thanks. I'll let you know result
Feb 5, 2016 at 9:56 AM
BABYHUEY42379
I tried the security system reset procedure. The security light goes out. So it will still start but shuts off 5-10 seconds later. Airbag light still on. Could it be Crank Sensor that may have been damaged?
Feb 5, 2016 at 10:46 PM
HMAC300
  • 48,601 POSTS
scan for codes , that still sounds like a security issue though which normally for airbag and security only a pro can scan for. it may be the air bag light on not allowing it to start
Feb 5, 2016 at 11:25 PM
