Wont stay running
178,000 MILES • 2.0L • 4 CYL • AUTOMATIC
CANDIA LANNING
I replaced the starter, battery. thermostat, fuel pump and filter. I checked all fuses changed around relays. It turns over, but it wont stay running. Please help I already spent $600.00 and I cannot afford anything else.
May 26, 2016 at 11:00 PM
  • 31,937 POSTS
You need to get a fuel rail pressure test done and be careful swapping relays, as the pins will look the same, but the actual function can alter, you have conventional and change over relays used. Check for codes and test for spark and injection pulse if you can as well.
May 27, 2016 at 10:37 AM
RENEE L
  • 1,260 POSTS
Hi Candia lanning,
Here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com. Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
https://youtu.be/YV3TRZwer8k
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jun 5, 2016 at 7:29 AM
