Won't start without prime, runs rough. Stalls on acceleration
87,000 MILES • 4.1L • V8 • 2WD • AUTOMATIC
TDRIVER301
I have no acceleration over fast idle, won't start without prime
Apr 2, 2016 at 10:59 AM
CARADIODOC
  • 34,415 POSTS
That sounds like a failed accelerator pump in a carburetor. Those come in rebuild kits which are rather inexpensive.
Apr 2, 2016 at 11:01 AM
TDRIVER301
I have throttle body fuel injectors
Apr 2, 2016 at 11:04 AM
CARADIODOC
  • 34,415 POSTS
Rats. Then start with checking for diagnostic fault codes. If there are none, you'll need a scanner to view live data. In particular, look at the throttle position sensor for proper response. If you have a mass air flow sensor, be sure there's no loose hose clamps or other leaks in the tube between the throttle body and sensor.
Apr 2, 2016 at 11:25 AM
