How long since a tune-up? Are there any applicable trouble codes? The basics, if it cranks good but will not start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gauge and check proper fuel pressure and fuel injector pulse. If you have more than one issue, check the crank sensor. The two most commonly replaced parts on your vehicle for, cranks good but will not start, is the fuel pump and crank sensor. I cannot rule out other issues? Do not replace anything unless your testing points in that direction.
May 7, 2016 at 6:55 AM
