Engine Won't start
190,000 MILES • 0.5L • V6 • 4WD • AUTOMATIC
ANBER14
Suv will turn over but no firing? Can you help me?
Jan 10, 2016 at 7:02 AM
WRENCHTECH
  • 20,760 POSTS
This sounds like you have a crankshaft angle sensor tha5t is out but to be sure this guide will walk us through the repair.
Jan 10, 2016 at 7:20 AM
SAM.SMALL
WRENCHTECH nailed it on my car I had to get a new crankshaft angle sensor cost me $122.00 all fixed! I love this site.
Oct 30, 2019 at 11:26 AM
LANIECEMILAN
  • 5 POSTS
Car won't start after lightbulb changed. Driver headlight went out. I purchased a new bulb took the car to a mechanic to have it replaced. Afterwards the car won't start. The car has power. The lights come on, radio works, doors work, but it won't start. The battery and alternator were both replaced in Oct. of 2012. The mechanic Confirmed the starter works. They tested it manually. They tested continuity all wires have power and the ground wire is connected. They removed the headlight harness and tried to start the car. Tried jumping it even though the battery test ok. Tried locking and unlocking the door. Tried starting it in neutral and pushing the car in gear. They tried an engine diagnostics, but the computer won't let them in. is there anything else I can have them exhaust?
Oct 30, 2019 at 11:27 AM (Merged)
HMAC300
  • 48,601 POSTS
check your starter fuse #15 in underhood box and relay first. if still won't start try resetting yur anti theft refer to your owners manual for that
LANIECEMILAN
  • 5 POSTS
I forgot to mention that part. All fuses are intact. Every fuse was pulled. I asked the dealer about disabling the anti theft they said they don't know. I had it towed from the local mechanic to the dealer this morning
HMAC300
  • 48,601 POSTS
that is pretty sad when a dealer doesn't have anyone that knows about anti theft. a scanner will pick it up if there is something amiss with it however. i'm sending a diagram of a fuse that may have burnt up but not checked it is a 200 amp one and is designed to protect the system it goes off the alternator. check that as well
DAKOTARED
Having trouble with my new car and hope you can help?
2007 Suzuki XL7 luxury 6 cyl 3.6l - Error code reads p0122 and the computer in the dash reads Engine Hot- A/C off. It turned over earlier but Car wont start now. Battery is new, all fluid levels ok. So... can you tell me
1) a PART NUMBER to search for to replace the TPS? or
2) better yet provide a SIMPLE STEP BY STEP instruction on how to ADJUST it?
Thanks!!
Oct 30, 2019 at 11:28 AM (Merged)
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole before replaceing tps. and we aren't parts people we on ly fix the cars. you really need a scan tool for this as1. it can bedamaged by improperly testing it and 2. it's a 2sided tps and both sides need to be checked.
DKM555
Car will not start--thought it was the battery, but, the lights all come on. Doesn't turn over or make any noise when turning the key. Could it be the ignition switch or the starter?
  • 55,691 POSTS
Hey DKM555,
Try putting the car in neutral to see if it could be the neutral safety switch,
Here is a guide that will walk you through a step by step trouble tree.
Please let us know happens so it will help others.
Best, Ken
CLAUTED02
I bought the car from a used dealership. After a week the car wont start. The first time that happened, I jump started it, It worked. Two days later the same thing happened again and this time it wont start anymore. Would you , please, tell me I there is a permanent solution to this problem?
CARADIODOC
  • 34,414 POSTS
Of course there's a solution. The vehicle didn't come from the manufacturer needing to be jump-started.
Jump-starting implies the battery is not being recharged while you're driving. That is the responsibility of the charging system. The generator is the most likely suspect. Start by measuring the battery voltage while the engine is running and with it off. With it running it must be between 13.75 and 14.75 volts. If it is lower than that the generator is not working but that could also be due to the voltage regulator which controls the generator.
If the voltage is within that range yet the battery is not staying charged the battery itself could be bad or the generator could have one bad diode of the six. A professional load test will find that. With one bad diode the generator will only be able to produce exactly one third of its rated output current. That's not enough to meet the demands of the electrical system under all conditions so the battery will make up the difference until it runs down.
With the engine off the battery voltage should be 12.6 volts. That shows it's fully charged. If you find closer to 12.2 volts the battery is okay but it's discharged. At around 11 volts or less the battery has a shorted cell and must be replaced.
CLAUTED02
Thank you so much for your answer it seems that is exactly what is happening with my battery. I think I have to replace it. But my other concern is : I was visiting a Suzuki forum, there is a lot of people that has the same problem with the same car. some of them have been changing : Alternator , Starter , and battery but they still have the same problem. A couple people think it might be the FUSE PANEL, LOOSE GROUND WIRE or WIRING problem between the IGNITION and the STARTER which is draining voltage. What is your opinion ?
Thank you for spending your time answering my questions. you are doing a very good job by helping people with their car problems. I have you in mind!
I which you wealth !!!
CARADIODOC
  • 34,414 POSTS
Sorry to be leaving you hanging so long. I'm spending almost every day out of town helping a friend.
Start with a professional load test on the charging system. In particular I'm interested in full-load maximum current and "ripple" voltage.
PICKLEROSE2
My daughter had a blow out on the rear passenger tire. This caused her to lose control and hit the curb, blowing out the passenger front tire. Car will not turn over now. Lights, radio and AC work, but there is not even a noise when you try to crank it. Is there a reset or kill switch built in that needs to be reset? There is not a Zuzuki dealer for miles around me.
HMAC300
  • 48,601 POSTS
try resetting security system not sure if that is problem but sounds like it. see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
NALABUG
My car died the other day while driving and I was told that my alternator went. I had it replaced, but now the car sputters when I am tring to start it. I have jumped it and it starts, but then sounds as if someone is revving the engine, while it is idiling. Also, every light is on, on the dashboard, and my radio wont even turn on. I know nothing about cars, and wish I could at least have an idea to see what to check. I have never had any problems before with the car and find it funny that all of a sudden everything is going... Can someone please help?
KHLOW2008
  • 41,812 POSTS
I would suggest starting with checking all the main fuses and testing the alternator charging, both between the battery terminals and between alternator main mast and body ground.
MWISENEZA
  • 6 POSTS
the car doesnt start and the nozzle cant inject enough pressure
  • 110,248 POSTS
Check fuel pump pressure to make sure the pump is producing enough pressure. Also, what do you mean by nozzle?
MWISENEZA
  • 6 POSTS
this car i change the pump but i didnt get enough pression i mean nozzle injector and i ask well the customer and say before the made the onother key for car and didnt start they put the memory of first key on transponder and car start after i use vehicle diagnostic computer say the pression of pump not enough so can i repair this pump is it repaired or not. mybe i need new your advice is important. thank you mr jacob and nicolas
  • 110,248 POSTS
If the fuel injectors are not firing, you need to check the voltage to them making sure it is within the manufacturer's specs. If it is low, the injectors will not work properly.
As far as the key, if the security light isn't on, the security system is working. It would shut down the fuel pump and spark to the engine.
FER750
I have 2004 suzuki grand vitara with 120k. Died on the highway while driving.
It has the following symptoms
1. cranks but no start.
2. When I turn the ignition switch on without cranking the ignition coils get extremely hot after few minutes and start smoking (it has six coils packs, COP) So far I have replaced 3 coils out of six? Is this electrical short? How to trace the short?
2. There is no power to the fuel pump relay from the ECM. When I test the power on the fuel pump relay the test light is dim.
3. The car after I turn the ignition switch on service engine light does not illuminate and nether communicate with OBDII scanner. it shows error link.
When responding please address each question separately.
Thank you
Fred
Oct 30, 2019 at 11:29 AM (Merged)
HMAC300
  • 48,601 POSTS
check to see if there is a fuse underhood for check engine light connection. check fuse box to see if it is a connector problem for relay. you might try using dielectric compound on prongs of relay and tweeking prong a little. coils may be getting hot because of not starting. hard to say on that one with out physically looking at it.
BUCKCINCY73D
had the camshaft sensors replace in my 04 xl-7 after a series of other problems. truck worked 3 weeks before it broke down again. was driving and started losing power until truck lost power and died. now it wont start at all or even turn over. put a ton in it and tired of it. need answers and all the mechanics I have been to cant tell me anything. looking for a cheap fix to get it running to get rid of it. enough Is enough. have no idea where to turn
HMAC300
  • 48,601 POSTS
check battery for condition and load test first if it won't turn over. if battery ok have an assistant try to start then smack body of starter if it turns over then you need a starter.
DOLORES FLORES
When I try to start the car, all it does it makes a clikcking sound, the light, radio and everything turns on, but it is showing the battery light on. and engine light.
SATURNTECH9
  • 30,869 POSTS
So is it the starter you hear clicking while trying to start it?Also i would have the battery tested and make sure the battery cable's are clean and tight.Also do you have a test light or a multimeter?
CARLOS22
went to start the car and it just clicked and the linside lights went out. I tried to jump start it and got the same results. Help please.
  • 75,988 POSTS
--Could be the starter motor, starter relay, clutch switch and ignition switch-Assuming the battery condition and connections are good.
CARLOS22
brand new battery, maybe 3 months old. Connections look good
KHLOW2008
  • 41,812 POSTS
If the inside lights means the dash indicators, check the ignition switch. While jump starting, if you had clamped the negative cable to the engine, it indicates the starter is most likely bad.
Disconnect the starter solenoid wire and use a remote wie to apply battery voltage to the solenoid and if starter fails to work, it is bad.
