It wants to start, but seems like it's not getting enough fuel. I have spark and there is pressure in the fuel line and the fuses look good.
Mar 2, 2016 at 2:41 AM
HMAC300
✓Experienced Mechanic
Check fuel pressure with a gauge, most auto parts stores rent it, may have a bad pump.
Feb 17, 2017 at 6:58 AM
CHRISBACA
MEMBER
I just replaced the fuel pump two months ago, it did get better, but not the over heating. Is there another shut off switch to look for?
HMAC300
There is an inertia switch in trunk I think it is if that is popped up you will get no fuel. Also, it may be your security system try another key if you have one then it will need to be scanned for codes which a professional has to do.
CHRISBACA
MEMBER
Is there a shut off switch if car gets hot
HMAC300
No. Why has his car been severly overheated? If it has you may have low compression.
