Won't start
237,304 MILES
CHRISBACA
It wants to start, but seems like it's not getting enough fuel. I have spark and there is pressure in the fuel line and the fuses look good.
Mar 2, 2016 at 2:41 AM
HMAC300
  • 48,601 POSTS
Check fuel pressure with a gauge, most auto parts stores rent it, may have a bad pump.
Feb 17, 2017 at 6:58 AM
CHRISBACA
I just replaced the fuel pump two months ago, it did get better, but not the over heating. Is there another shut off switch to look for?
HMAC300
  • 48,601 POSTS
There is an inertia switch in trunk I think it is if that is popped up you will get no fuel. Also, it may be your security system try another key if you have one then it will need to be scanned for codes which a professional has to do.
CHRISBACA
Is there a shut off switch if car gets hot
HMAC300
  • 48,601 POSTS
No. Why has his car been severly overheated? If it has you may have low compression.
CHRISBACA
How much pressure should I have in my fuel line?
HMAC300
  • 48,601 POSTS
37-43 psi key on only 26-45 psi engine running.
