Won't start
126,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
DAZZER121
Car was running fine but noticed water pump was leaking so replaced pump now car won't crank over
Jan 16, 2016 at 5:38 AM
CATAFINA
  • 167 POSTS
Check for disconnected wires and fusible links, start here
Apr 2, 2018 at 1:33 PM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online if waterpump was replaced and timing belt moved that may be the problem as well.
DAZZER121
Timing belt was not moved engine turns but will not crank over
CJ MEDEVAC
  • 11,000 POSTS
WILL NOT CRANK OVER
OR
WILL NOT START/ BUST OFF/ RUN?
DAZZER121
When you you turn key serpentine belt goes round but no cranking
HMAC300
  • 48,601 POSTS
how can the serpentine belt move and doesn' t crank? you mean it won't run? check fuse 12 & 18 under hood and see if you have any fuel pressure with a gauge auto parts rent it
