Won't Start
180,956 MILES • 2.4L • 2WD • AUTOMATIC
YOLIE_BEEOTCH
Was making a clicking noise replace starter. No clicking now but still won't start.
Dec 20, 2015 at 8:34 PM
I assume it is turning over???
you need compression, spark and fuel to run. you need to check what is not there to further check for the failure.
try spraying some carb cleaner into the air filter and see if it starts and stalls.
Dec 20, 2015 at 8:40 PM
YOLIE_BEEOTCH
Thank U Roy for your reply. Nope it doesn't do nothing now. No clicking there is power light inside and out work.
Dec 20, 2015 at 9:40 PM
ok, start with voltage check at the battery. you should have at leat 12 volts
Dec 20, 2015 at 9:51 PM
YOLIE_BEEOTCH
Thanks Roy. K so if the battery does read 12 Volts. Then what should I check ?????
Dec 21, 2015 at 12:21 AM
check voltage at the little wire on the starter solenoid. it should have 12 volts when it start mode only
Dec 21, 2015 at 12:34 AM
