Will not crank
91,000 MILES • 5.0L • V8 • AWD • AUTOMATIC
FRANKSLASTBEMZ
I changed the brake light switch and now the car will not crank. I have esp message. All lights work. Key turns.
Jun 15, 2016 at 11:02 PM
AL514
  • 5,679 POSTS
I would recheck your wiring under the dash, you may have a loose wire under there that loosened up while you were replacing the brake switch.
Jun 16, 2016 at 12:07 AM
  • 55,554 POSTS
Hey FRANK
Love the user name btw. They are a tough car to have for sure. Please recheck the job you just did I sure you must have bumped something or pulled a wire somehow. Disconnect the battery for 5 minutes to reset the security system,
Here is a guide that might help you.
Best, Ken
Jun 18, 2016 at 2:32 AM
