Won't crank
2006 FORD F-250
156,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
EMORYCOX24
4 months ago, I came outside got in my f250 to go to work, it would not crank. I just found out that somebody has filled my fuel tank with sand, what should I do.
Feb 5, 2016 at 1:28 AM
HMAC300
  • 48,601 POSTS
drop the tank and take the sand out change fuel filter and see if sock on pump is clogged when tank is out.
Feb 5, 2016 at 1:34 AM
HMAC300
  • 48,601 POSTS
that won't have anything to do with it not cranking though. check battery for condition including load test then try resetting security system. if no manual look online.
Feb 5, 2016 at 1:35 AM
EMORYCOX24
Okay thanks, I was told it was junk now. By a couple now
Feb 5, 2016 at 1:36 AM
EMORYCOX24
Thank you man
Feb 5, 2016 at 1:38 AM
