This is how it started.went to the store came out and it would not start. Noticed that I did not hear fuel pump run and gas gauge did not move.engine cranked over fine. I knew I had gas so thought fuel pump relay, or pump or something that controls it called tow truck,after about half an hour I tried to start it. Turned key on and noticed gas gauge was working. Car started and I drove it home. This happened several more times the same way until now. It will not start at all. Gas gauge does not move, security lock goes out, with other warning lights. From what I read sounds like a BCM is bad. I tried this and it did not work. Parts are used. I replaced out of same car ECM, BCM and ignition switch from 2005 and had same result, no start. Thought car maybe had same problem.
Jul 22, 2018 at 7:36 AM
