Wobbling front passenger side front end?
300,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
CANDY BALLANTINE
When I drive my car, it feels like my tire is wobbling or like something is loose.
Jun 12, 2023 at 9:13 PM
BORIS K
  • 836 POSTS
A "loose" wheel feeling can be caused by many possible issues.
The most common ones are below:
1. Are the wheels tight? Loose or missing wheel bolts can cause this
Check that all wheels are tight, and all bolts are fitted.
2. Worn wheel bearing.
A bad wheel bearing can cause wheel wobble and humming noises while driving.
A good link:
https://www.2carpros.com/articles/symptoms-of-a-bad-axle-or-wheel-bearing
3. Worn suspension components like ball joints and tie rods.
Good videos:
https://youtu.be/6M2D_XtuXZQ
and
https://youtu.be/scFbb43fwqk
Please let us know if you need more information.
Cheers, Boris
Jun 12, 2023 at 10:56 PM
