wiring to fuel pump fixed fuel pump and maybe its in the wiring??
1997 PONTIAC SUNFIRE
126,000 MILES
SHERRY04
Replaced fuel pump..crank sensor and checked everything and car wont fire..checking coil packs now ..idk wat else it could be and dont have the money to put it in the shop..fuel pump went out due to a wire..something in the wiring??
Aug 30, 2013 at 6:36 AM
TY ANDERSON
  • 719 POSTS
There are things that need to happen to make and engine run. There needs to be spark, the right amount of air/fuel mixture, compression and timing. I would check for spark from the spark plugs first, then check fuel pressure. Check those things first then get back to me. Talk to you soon, TY
Aug 30, 2013 at 12:21 PM
