The alternator is not charging even with a new alternator. The old one was wired with the feed from the battery terminal going to the ignition module through the hot wire from the battery to the ignition module. The field wire terminal was wired to the a port on the regulator and had a second wire going nowhere but had a plug on it that appeared to go to the carburetor. The ground prong on the alternator was not grounded and the starter terminal was not connected. Needless to say i didn't make it far before my battery was dead.
Mar 21, 2019 at 10:16 AM
