wiring problem,van only starts with code scanner
150,000 MILES • 3.8L • 6 CYL • AWD • AUTOMATIC
SHANEBENZ
2000 Chrysler town and country. Another mechanic had replaced the head gasket it no longer starts. Checked all the normal issues. Can hear loud clicking from the relay box. I plugged a obdll code scanner to it and it will start and run fine. Throws no codes. But if you unplug the scanner. It will not run. Why will it only start and run with code scanner connected?
Sep 1, 2014 at 9:55 AM
HMAC300
  • 48,601 POSTS
try resetting anti theft unit first then have a pro scan it. if no manual look online
Sep 2, 2014 at 12:48 AM
JAYE2468
I had a similar condition with my 2001 voyager. It wouldn't start unless I had the OBD2 scanner connected. In my case, the thin ground wire that comes off the negative battery terminal was not getting a good ground do to corrosion. I had to remove battery and battery box to reach the ground point under the battery on the fender. After cleaning this connection point, the van started with no more problems.
Oct 20, 2014 at 2:14 AM
