Wiring problems?
132,159 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
19BIGMIKE94
While driving every light goes off the mileage sets to 000000 and every gauge dances hard except the battery voltage gauge then it goes back to normal. Mostly happens when I get down on it to get on the highway. It doesn’t lose power or skip just the dash. Last night I replaced the starter and this morning it started acting up. Not sure if I did something wrong when replacing the starter. I appreciate it.
Sep 14, 2022 at 8:43 AM
MIKE H R
  • 3,094 POSTS
check your wiring, make sure you have a good ground from the battery to the engine and a good ground to the chassis.
Sep 14, 2022 at 9:00 AM
  • 55,711 POSTS
This happens when the instrument clusters go out, you will need a rebuilt unit here is a video of the job being done on a similar vehicle.
https://youtu.be/_HEC44xENxw
Sep 16, 2022 at 3:16 AM
