Wiring problem
151,000 MILES • 0.6L • 6 CYL
HELPINGHANDS
I have a back up sensor,there's a bulk wire and a bulk and red wire on unit. What wires do I hook up to on my van after removing the tail light housing?
Jan 13, 2020 at 6:20 AM
STEVE W.
  • 15,423 POSTS
What is the sensor for? Is it a factory part or something like an aftermarket camera or warning system? If it's an aftermarket item could you post the make and model of the unit. That would let us look up the wiring. I think you are adding a back-up camera that needs a ground and a signal from the back-up lights but without knowing which wire was which on the part you have I wouldn't want to have it wrong.
Jan 13, 2020 at 7:23 AM
