Wiring in door jam
200,000 MILES
AIMEEC123
I just need to know if the wiring in the case of the jam has a connector piece or do you have to cut the wires?
Nov 9, 2018 at 4:03 PM
  • 55,770 POSTS
Yes, it has a connector which is inside the car. Follow the harness through the body and above the kick panel you will find the connector. Please let us know if you need anything else to get the problem fixed.
Cheers, Ken
Nov 12, 2018 at 3:02 AM
