Wiring harness for spark plug coils is brittle and losing connectivity
V8 • 2WD • AUTOMATIC
ZITOK
  • 9 POSTS
The vehicle is missing. The connections to the ignition coils is loose due to the plastic connectors being brittle and no longer locking into place. These harnesses are no longer available from dealerships. Where can I get a new one, or how can they be repaired.
Thanks in advance.
Apr 23, 2014 at 11:49 AM
CADIEMAN
  • 3,544 POSTS
cut the old ones off and buy new connectors to crimp on
Apr 23, 2014 at 3:50 PM
ZITOK
  • 9 POSTS
So the connectors are available? But the complete harness isn't. I would have expected the butch in parts to tell me that. I'll go see it today .
Thx cadieman,
KZ
Apr 24, 2014 at 4:03 AM
CADIEMAN
  • 3,544 POSTS
DID U EVER FIX YOUR CAR?
Oct 27, 2014 at 11:40 AM
ZITOK
  • 9 POSTS
Turns out that the connector wasn't the problem this time. After I made sure that the connector was connected properly the engine light cam on again. On closer inspection I found that the spring that is in the top of the rubber boot that goes over the spark plug had broken. I shortened it and the problem was still there, so I replaced entire boot assembly and that fixed it.
Thanks for your reply.
Oct 27, 2014 at 12:58 PM
CADIEMAN
  • 3,544 POSTS
GOOD TO HEAR
Oct 27, 2014 at 11:04 PM
