Wiring diagram to follow wires from O2 sensor to TIPM
100,000 MILES • 3.8L • V6 • AUTOMATIC
LAWRNY
I have not been able to find connector diagrams. O2 connector to computer. No power to sensor.
Dec 27, 2018 at 3:06 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the wiring diagram you requested. The H02 sensors are wired to the PCM (Power-train Control Module) I've attached engine wiring diagrams below. Here is a link for a tutorial showing how to test wiring:
Hope this helps and thanks for using 2CarPros.
Danny-
May 8, 2021 at 10:31 AM
LAWRNY
I need the connection at the other end. TIPM. Thanks
Good afternoon.
I attached the wire diagram for you to view.
it shows the O2 sensor's wiring back to the PCM.
The TIPM has no involvement in the operation of the O2 sensors.
LAWRNY
Thanks.
