Wiring diagram to add Illuminated sill plates
48,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
STUPAK
Vehicle listed above an EX model with both technology packages, and I am looking to add some sill plates, specifically:
https://www.k5optimastore.com/collections/2016-kia-optima-product-collection/products/2016-optima-sequential-door-scuff-plates
Any help with a wiring diagram, or any other tips about where to tap in for the power and ground. My car comes standard with door handle lights that light up when you approach/unlock the vehicle and the power mirrors auto tilt back out.
Feb 1, 2020 at 11:43 PM
STEVE W.
  • 15,399 POSTS
Looks like install instructions are here:
https://www.optimaforums.com/threads/installing-illuminated-door-sills-on-ex-lx-optimas.8840/
However I would not use the scotchlock type tap connections, I would instead strip some of the insulation off the wire, then wrap the power and grounds around the correct wires and solder them. Next use liquid electrical tape to seal the area to keep corrosion from destroying the wires.
Feb 2, 2020 at 4:19 AM
STUPAK
I will let you know the outcome, as my model differs from this older model.
Feb 2, 2020 at 6:34 AM
STEVE W.
  • 15,399 POSTS
It looks like you may have the correct wires to plug them in if the wiring diagram is correct. It shows red and blue wires for the drivers side and green and white for the passenger side. These wires would likely be within the reach of the connectors on the new plates.
Feb 4, 2020 at 12:50 PM
