Can I get a wiring diagram for reversing light connection for rear cam?
11,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
ADY1966
I am fitting a reversing cam to my vehicle listed above Max, and I need to attach a wire to the reversing light on the rear. I have managed to run the cable to the nearside light cluster but need to know what color cable goes to the reversing light so I can attach the cam to it. I am using a wireless reversing cam.
Cheers, Ady
Aug 6, 2022 at 12:39 PM
  • 110,244 POSTS
This model isn't offered in the US, but if you remove the light assembly, you should be able to identify the wire going to the reverse light.
I tried to find something similar here, but they don't offer anything. Also, VW likes to use different color wires for each side.
Let me know if/when you remove the reverse light if you can identify the wire.
Aug 6, 2022 at 3:21 PM
