I need the wiring diagram for the DCM to the driver side mirror. For the power heated mirror and turn signal indicator. Thanks
Feb 16, 2020 at 7:57 AM
✓Experienced Mechanic
I attached the DCM schematic for the left door. Let me know if it helps.
Images (Click to enlarge)
Feb 16, 2020 at 8:31 AM
Here is the diagram for the DCM to the heated mirrors and the last two are for the turn signals in the mirrors. Let me know if you need more. Thanks
Feb 16, 2020 at 9:00 AM
RANDY ALBRIGHT2
MEMBER
I still need the pin out leaving the DCM on 1 and 6 going to left side miror where it connects to 4 different functions. The turn signal(done), the mirror heater, the mirror motor, and dimming feature. The mirror motor uses a plug with 7 wires while the other three use only 2 wires. That’s 13 wires total to terminate using module 1 and 6 from the DCM. So a pin out for these or a diagram sure would help. Thanks again.
Feb 16, 2020 at 7:00 PM
Unfortunately, I could not find a connector view which would be great. so I think I got all the circuits you need for the front left door control module.
Let us know if we missed something and we can go after that. Thanks
Feb 17, 2020 at 12:01 AM
RANDY ALBRIGHT2
MEMBER
Thanks but still need wiring diagram for the drivers side mirror motor that moves mirror.
Also module 6 on the dcm. Also module 1 from the DCM. I need to know the config. for the 8 pin connector that goes to side mirror motor. And module 6 on DCM and where it terminates. Thanks again.
Feb 17, 2020 at 12:44 AM
RANDY ALBRIGHT2
MEMBER
I need the wiring that goes into the side view mirror motor. Thanks. This is for 7 wires in a 8 pin module.
Feb 17, 2020 at 1:50 AM
RANDY ALBRIGHT2
MEMBER
Feb 17, 2020 at 3:12 AM
Let me know if this is what you are looking for. I have schematics all over the place. LOL
Feb 17, 2020 at 5:20 AM
RANDY ALBRIGHT2
MEMBER
Howdy thanks for the help. I am still looking to see schematics for the c6 on the DCM. And she what it supplies.
Feb 17, 2020 at 5:57 AM
RANDY ALBRIGHT2
MEMBER
Schematics for c1 And c2 on the DCM? Thanks
Feb 17, 2020 at 5:59 AM
Okay. I switched from AllData to Mitchell and they seem to have more diagrams. Here is C6 from the DCM to the Power Mirror motor.
C1 for the dimming function. However, it only has Pin 1 and 6. I am looking for the others.
C2 Pin 1-3 are included and it appears that is all on that connect. Is that correct according to the vehicle?
Feb 17, 2020 at 7:35 AM
RANDY ALBRIGHT2
MEMBER
I’m sorry but I meant c6 not c2. C6 is what has been the missing link.
Feb 17, 2020 at 7:55 AM
RANDY ALBRIGHT2
MEMBER
Never mind I see the c6. You are awesome to stick with it. Many thanks now I won’t do the work 5 times.
Feb 17, 2020 at 8:04 AM
