Wiring diagram
140,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DIGIELINSKI
I am looking for the wiring configuration/ pin out for the power windows and power locks for a 2009 F-150 super cab.
Feb 25, 2016 at 12:11 PM
HMAC300
  • 48,601 POSTS
See pictures below.
Feb 25, 2016 at 11:09 PM
JDL
  • 16,098 POSTS
The information I looked at was for 2009.
The diagram is for power windows. Check for voltage at circuit breaker. Also, check wiring on hinge side of driver door. The driver door is open and closed so much, sometimes the wires in the harness may break?
Check for applicable trouble codes, see if codes point at the sjb/smart junction block. Some of the national brand auto stores will check codes for free, I am just not sure if they will check manufacturer specific codes? It does not hurt to ask.
Feb 25, 2016 at 11:26 PM
JDL
  • 16,098 POSTS
I did not see you, hmac, have a good day.
Feb 25, 2016 at 11:27 PM
DIGIELINSKI
Thanks guys. My truck came without power windows so I added them, I got oem door panels and switches so I just needed the pinout for those. Thank you!
Feb 25, 2016 at 11:29 PM
  • 55,694 POSTS
Glad to help nice work guys :-) Please use 2carpros.com again and tell a friend.
Mar 7, 2016 at 8:52 AM
