Wiring and not starting
234,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
JONESBA27
Wires that are red green and black and it won't start.
Jul 30, 2019 at 4:25 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Can you describe what is happening with the wires you mentioned? Also, is the starter engaging or does nothing happen?
I attached 2 pictures. They show the entire starting system (starter circuit). I had to break it into two pictures to make it readable, but I did overlap it so you can follow it. Let me know if the wires you are referring to are shown in the schematic. Also, I need to know what is happening with the wires you mentioned.
If the starter is in question, here is a link that shows how to test a starter:
Here is a link related to a crank/no start condition:
Let me know if any of this helps or if you have other questions.
Jul 30, 2019 at 11:43 PM
