It's got three red wires not attached, and it won't start?
197,000 MILES • 2WD • AUTOMATIC
DENISELYN89
I had someone ask me to fix their car. It's got three red wires not attached, and it won't start. There was a new ignition put in. I just need some guidance on what to do.
Feb 5, 2020 at 11:26 PM
  • 110,251 POSTS
The ignition switch should have a plug. Where are the three red wires located? Have you checked to see if they have power at all times?
If you look below, I attached a pic of the wiring schematic at the ignition switch. There is one red wire in, one red/black wire in, and then other color wires out. Let me know if that helps. Also, take a pic of the wires and upload them for me to see.
Here is a link you may find helpful when checking wiring and connectors:
Let me know what you need or what I can do to help.
See pic below.
Aug 13, 2021 at 12:27 PM
