Wiring
12,115 MILES
APRIL0005
My 94 dodge colt was running great then it started cutting off while driving parked it and the next morning won't spin over battery is fine and alternator is good? Do not have any power what's so ever no head lights brake lights nothing. Whats wrong with it ?
Feb 6, 2016 at 9:38 PM
JOHNNYT73
  • 924 POSTS
Have you had the battery and alternator tested? If so, and good. Check your fuses and wiring to and from battery and alternator.
Feb 6, 2016 at 10:50 PM
APRIL0005
I have the starter was bad had it replaced. The alternator is good all fuses are good I have power to the starter but no where else
Feb 6, 2016 at 10:55 PM
  • 55,562 POSTS
Hi Johnny, thanks for helping, it sounds like the ignition switch or a fusible link is the problem
Feb 9, 2016 at 10:39 AM
APRIL0005
New ignition switch and all fusible links look good no blown fuses .
Feb 9, 2016 at 11:44 AM
  • 55,562 POSTS
To the fuse box there is main power feeds coming from the starter or battery terminal remove the fuse box to test these main power feeds, you have one of them not working
Feb 11, 2016 at 1:01 AM
