Wires on fan are damage
67,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
AUSTINO
  • 231 POSTS
Good evening, it was discovered that the wire that runs from the fan to the connector is damaged. We would like to know where the little white and blue wire connects to. Can you please send a schematic wiring diagram showing where the wire connect to please, if you can? Please see images of wire below. Thank you in advance guys!
Jan 31, 2019 at 7:24 AM
  • 110,251 POSTS
Hi and thanks for using 2carpros.com
The White/Blue wire runs from the fan module behind the radiator to the ECU located at the rear of the engine compartment. I have attached a schematic showing this.
Jan 31, 2019 at 10:49 AM
AUSTINO
  • 231 POSTS
Feb 1, 2019 at 4:34 AM
  • 110,251 POSTS
Glad to help. Let me know if you have other questions or need help with something.
Feb 1, 2019 at 4:59 AM
AUSTINO
  • 231 POSTS
Before you sent this information. I tried connecting the little white and blue wire to another wire somewhere as result the fan works but it doesn't chip out.
Feb 1, 2019 at 5:03 AM
  • 110,251 POSTS
Not knowing what you attached it to makes it hard. However, it must have been direct to the fan. Does that sound correct?
Feb 1, 2019 at 7:34 AM
AUSTINO
  • 231 POSTS
Good morning, yes the wire was directed to the fan, you are correct.
Feb 1, 2019 at 8:19 PM
  • 110,251 POSTS
Okay, then what I think you did was bypass the ECM and took power right from the fan module.
Feb 2, 2019 at 12:22 PM
AUSTINO
  • 231 POSTS
Okay, thank you.
Feb 2, 2019 at 8:31 PM
  • 110,251 POSTS
Let me know if you have other questions or need anything.
Feb 3, 2019 at 10:32 AM
AUSTINO
  • 231 POSTS
Okay sir.
Feb 3, 2019 at 10:12 PM
