wire harness to plug on tranny
120,000 MILES • 6 CYL • FWD • AUTOMATIC
DUGGER
rat ate thru wires coming from harness to tranny........causeing hard shift from 1st to 2nd.......wires were compromised right at connectors WHERE 3 WIRES GO TO 2 !!!!!!!!!???? one of the 3 (coming from harness) is uninsulated..........should i include it in splice---i think i know which one of two it would have been with?????
Mar 11, 2014 at 1:34 AM
CJ MEDEVAC
  • 11,000 POSTS
IF YOU WANNA KNOW IF 2 CONNECT TOGETHER IN THE CONNECTOR
RUN A CONTINUITY TEST FROM THE "2 SIDE" TO THE "3 SIDE"
"HARBOR FRIEGHT" HAS DIGITAL VOLTMETERS STARTING AT $5-AUTO PARTS STORES ABOUT $20................A 12 VOLT TEST LIGHT $3-$20
I'VE USED A FLASHLIGHT---TURN ON THE FLASHLIGHT, REMOVE THE TAIL END, USE JUMPER WIRES FROM THE BODY---ANOTHER TO THE END OF THE BATTERY---------TOUCHING THE JUMPERS TOGETHER WILL LIGHT UP THE LIGHT.........TOUCHING THEM TO EITHER END OF SOMETHING CONDUCTIVE.....WILL TURN IT ON TOO
WAH-LAH! INSTANT AND CHEAP CONTINUITY TESTER!
GIVIN' YOU 3 HOMEMADE PICS OF HOW YOU CAN DO THIS......SORRY, DON'T HAVE ONE FOR THE FLASHLIGHT........IF YOU WANT, I CAN MAKE ONE....I AIN'T SKEERED!
LEMME KNOW HOW IT GOES
THE MEDIC
Mar 11, 2014 at 11:56 AM
DUGGER
not sure what cont test would tell mee......................anyway i put it together and followed my instinct and paired the bare wire with one of the two---------problem solved.......................thanks for your input!
Mar 12, 2014 at 12:20 AM
CJ MEDEVAC
  • 11,000 POSTS
SORTA THOUGHT IT WOULD TELL YOU IF THE 3 WERE SEPARATE AND ONE WAS UNUSED
OR WHICH 2 HAD THE SAME CONTINUITY TO WHICH PIN ON THE OTHER SIDE
OH WELL........GLAD YOU GOT IT FIXED!
COME BACK TO SEE US........WITH A PROBLEM WITH YOUR BUDDY'S CAR........KEEP YOURS "GOOD TO GO"!
THE MEDIC
Mar 12, 2014 at 7:53 AM
HMAC300
  • 48,601 POSTS
if this is the correct one in pic this is how it goes if not give me the wire colors and i'll send the correct ones
Mar 13, 2014 at 12:50 AM
