Wire harness from crankshaft position sensor to ignition module has failed.
130,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
DAVE_TX
The insulation is flaking off the wires in the wire harness from the crankshaft position sensor to the ignition module. Ford does not stock replacement harnesses. Where can I go for a replacement? I'm even willing to build the harness myself with automotive wire, a hi temp loom, and the correct connectors if I can find them. Where would I find replacement connectors?
Sep 29, 2014 at 7:35 AM
HMAC300
  • 48,601 POSTS
try American auto wire they are on the internet
Sep 29, 2014 at 8:20 AM
