Which wire is for the low beam light passenger side
Feb 19, 2014 at 6:56 AM
HMAC300
✓Experienced Mechanic
violet and red, but have it scanned your tpim module is probably shot if light bulb is good.
Feb 19, 2014 at 10:58 PM
BIGDOG1974
MEMBER
Can I run a wire from the passenger side light to the driver side cause my left low beam light don't work right now I have a wire from the driver side low beam light going to the fusebox so when I turn the key on the light comes on
Feb 20, 2014 at 6:04 AM
HMAC300
I heard of other people doing that you can if you like. I would not recommend it though
Feb 20, 2014 at 8:07 AM
BIGDOG1974
MEMBER
Ok what do you think will happen
Feb 20, 2014 at 8:25 AM
HMAC300
besides putting an extra load on the tpim module which the headlights are connected to, possibly a fire for one, destruction of the tpim module which effects a bunch of stuff in your car. Other than that nothing.
