Wire for the high pressure fuel pump?
100,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I just put another motor on this car. It's not an AWD, i can't seem to find the connector going to the hpfp on the passenger side which is right on to of the valve cover. Can you find out for me which harness patch does it come out from? All coils and injector wires are in but no separate wire is found coming from there. It's a 2 wire connector. You will see where it plugs into the pump, grey connector on pump.
May 3, 2024 at 4:08 AM
  • 110,248 POSTS
My wiring schematics aren't set up in a way to know where the harness would be located.
However, it should be a 2-wire connector and if I recall, the wires are red and white. Also, they should travel to the HPFP from under it. Have you checked closely under the pump?
joe
May 5, 2024 at 11:13 AM
BHAMDOC1973
  • 2,007 POSTS
Found it plugged in on the other side of motor on another sensor. Yes, red and white. Thanks
May 5, 2024 at 11:33 AM
  • 110,248 POSTS
You are very welcome. I'm glad you found it.
Take care and feel free to come back anytime in the future.
May 5, 2024 at 1:40 PM
