Wipers will not operate
165,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SLIMONTIME
  • 19 POSTS
I just redid the body ground on front left body. Well, fixed the one problem but I now have no wipers and half the dash lights (right side) are out. I cannot find the wiper module to check wiring. Seems not to be relays (changed) or fuse. I have ground at PCM. What am I fighting here?
Oct 30, 2017 at 3:22 AM
  • 110,246 POSTS
First, check to see if there is power to the wiper motor. If there is, make a jumper wire directly from the motor to ground on the battery to see if that is the problem. As far as the dash lights, create a new ground from the body (firewall) to a known good ground to see if that repairs the problem. If none of the above suggestions help, consider having the body control module tested. Since the items worked before you repaired a ground issue, something is telling me you simply created a new ground problem for other components.
Oct 31, 2017 at 11:40 AM
