wipers and clock
112,500 MILES • 6 CYL • FWD • AUTOMATIC
HOWARD55
clock and wiper relay are in the same circuit.testing the blue/white of the ignition switch for battery voltage.I bought a new relay and it lasted a month and started having the same problem.If I turn the car off and re-start the car the wipers and clock will work for a while and then stop.I have to repete the process over.I asume the blue/white is the problem.Do I need a new switch or what do I need to do to slove the problem
Dec 5, 2016 at 8:27 AM
HMAC300
  • 48,601 POSTS
check to see if wire is grounding out in dash or on body especially if something was recently installed it may be a screw causing it. then check switch.
Dec 5, 2016 at 11:12 PM
