Wipers stopped working
63,000 MILES • 0.5L • V8 • 4WD • AUTOMATIC
KYLE ROBICHAUD
Hey, my windshield wipers stopped working, but when I try to turn them on my headlights come on.
Jul 27, 2018 at 1:56 AM
  • 55,694 POSTS
lol, that is funny. It sounds like the BCM has gone bad which you will need to get programmed into the truck which should cost about $130.00 if you have your own BCM here is the location of the unit. I would remove the unit and check the connectors for corrosion from moisture which will cause the issue.
Cheers, Ken
Jul 29, 2018 at 6:37 AM
