Wipers
173,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIPHILLI4
Turned on one was frozen in place heard a pop checked fuse good, but need to know where breaker is?
Jan 11, 2018 at 2:05 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
There is no circuit breaker, just that "wiper" fuse in the fuse block located behind the right side of the dash.
That wiper fuse is fed from the ignition switch and the ignition switch is fed from a IGN Main 1 maxi fuse in the underhood fuse center.
Jan 12, 2018 at 10:37 PM
