Wiper Relays
113,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
KAZOO2013
Hello, I just bought this truck, and the wipers have stopped working. I am overseas military and took it to a mechanic, who replaced the wiper motor and then charged me $400.00 after he could not resolve the problem. I then took the truck to a local Ford dealer, who had to order the wiring diagram because this is a US model vehicle and not produced in the country I am stationed. Now, I am being told that it is the master relay and that these parts are very expensive. How can I be sure the Ford dealership is being honest with me? The parts manager said there are two types of relays....one is rather cheap, but the master relay is very expensive. If I were to get the code from the dealership, what numbers should I be looking for in order to tell me it is the master relay switch? Thank you!
Apr 19, 2016 at 2:57 PM
HMAC300
  • 48,601 POSTS
check the two relays and fuses in pic he may be talking about the GEM module in the USA you can get them used for around 50-125 dollars which may nneed to be programed
Apr 19, 2016 at 11:55 PM
RENEE L
  • 1,260 POSTS
Kazoo2013,
Thank you for your service in the military.
Renee
Admin
May 20, 2016 at 8:13 AM
