Wiper motor
153,789 MILES • 2.3L • 4 CYL
BARRYB66
I have voltage to the motor but nothing happens. New motor. I connect it straight to the battery and it works. No matter what position the switch is in I have voltage to every wire (6 pin) except when switch is off. What could this be?
Dec 13, 2017 at 11:24 PM
CARADIODOC
  • 34,415 POSTS
Most likely the ground is missing. Start by testing for voltage on the motor's housing. Put the meter's negative probe or the test light's clip lead on any ground other than the plate the motor is bolted to. Wiper motors are usually mounted to a metal plate that is mounted with rubber isolators to dampen vibration. There is a brass strip riveted to the plate, and run under one of the bolt heads. That strip arcs away under the bolt head. Often the motor will run intermittently, and when you push on it.
Do not bother trying to fix that brass strip. Just find a place where you can attach a ten gauge jumper wire to the plate or motor, and the other end to a paint-free point on the body.
Dec 14, 2017 at 6:41 AM
BARRYB66
I understand the ground, but it is a new motor. If that is not the problem what else should I look for?
Thanks
Dec 15, 2017 at 1:09 AM
BARRYB66
I understand the ground,but it's a new motor. If that's not the problem what else should I look for?
Thanks
CARADIODOC
  • 34,415 POSTS
Did you bolt the motor to a metal plate? That plate is what's mounted on rubber isolators and has the bad ground. Did you check for voltage on the motor's metal housing?
Dec 15, 2017 at 7:56 AM
