Wiper motor
61,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
RICHARD CORNISH
Positioning motor crank arm to new motor. Should arm be positioned in park location at 9 o’clock and then installed to arm mechanism and then crank arm rotated by hand to 3 o’clock to get into cowl area. I assume the new motor is in park position from factory. I should be able to rotate crank arm by hand to 3 o’clock by hand just as I did we old motor removal. Is this correct procedure?
Feb 21, 2021 at 1:56 AM
STEVE W.
  • 15,419 POSTS
Connect up the motor and turn it on, some come in park position but not all. Let the motor cycle and return to park then attach the crank arm. You may want to verify its rotation first though, if the arm is in the wrong position the arms can crash instead of going up the glass. Once you are sure the motor is in the park position then you can attach the arm and rotate it to position to get it into the cowl. Then test it once the motor is in place before attaching the wiper arms so you are sure it's in position.
Apr 21, 2021 at 5:39 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached picture removal and replacement steps below for the windshield wiper motor on your vehicle. I've also attached the wiper motor electrical diagram below if needed. Here is an electrical wire testing tutorial as well:
Hope this helps and thanks again for using 2CarPros.
RICHARD CORNISH
Thank you for answers to technical questions on wiper motor removal and installation. No issues other than rain sensor interacts with delay and wiper speed. When spraying windshield sensor area the system seems to be operating fine. Washer pump working fine!
I attached the position of the arm for the park position below and how far you need to rotate the arm to remove and install.
5. Pull or push on the wiper transmission linkage to rotate the wiper motor crank arm (2) from the park position (1) to the area opposite the park position (3).
DANNY L
  • 5,648 POSTS
Hello again.
Hope our information helped. Let us know if you have any further questions on this issue. Thanks again for using 2CarPros.
Danny-
Apr 21, 2021 at 5:40 AM
