wiper and washer?
110,000 MILES • 2.3L • 4 CYL • AUTOMATIC
GSWANGLER
windshield wipers only work on high and do not return down when turned off. Washer quit working at the same time
Jul 11, 2025 at 11:37 AM
  • 55,694 POSTS
Lets check the fuse # f29 - 30 amp in the fuse panel under the hood on the left side. This guide can show you how and I have the location in the images below.
Jul 12, 2025 at 3:48 AM
GSWANGLER
both fuses were ok.
Jul 12, 2025 at 12:11 PM
  • 55,694 POSTS
Sorry, I should have you check the 5 amp fuse #5 in the smart junction box at the same time which is at the right kick panel. Here is the location. Check out the images (below). Let us know how it goes.
Jul 13, 2025 at 5:01 AM
  • 55,694 POSTS
This wiper system has a logic module and a switch that controls it, Also, check the ground G103 at the left side of the engine compartment. Here is the wiring diagram for the system so you can see how it works. If the fuse and ground are good chances are the switch or wiper motor are bad, you can use a voltmeter to test through the switch by following this guide.
If the switch is good replace the wiper motor. Check out the images (below). Let us know what you find.
Jul 13, 2025 at 5:14 AM
