Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Element
Body
Windshield
Washer
Pump Motor
Windshield washer fluid pump
2008 HONDA ELEMENT
120,000 MILES
RAW5823
MEMBER
Windshield washer pump sprays in the rear, but not in the front of the vehicle. Pump can be heard for rear, not for front.
Aug 6, 2016 at 8:33 AM
HMAC300
Experienced Mechanic
check fuses under hood first, then it is probably the pump not working as they use two different pumps.
Aug 6, 2016 at 8:53 AM
RAW5823
MEMBER
Thank you. I thought they had separate pumps. Do you know how the fuse port is marked. I looked and could not tell.
Aug 6, 2016 at 8:56 AM
HMAC300
check on inside cover US auto makers put it there which is which or your manual if you have one.
Aug 6, 2016 at 9:29 AM
RAW5823
MEMBER
Thank You!
Aug 7, 2016 at 11:21 PM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
