Windshield wipers not working properly, relay location needed
64,000 MILES • 6.7L • TURBO • 4WD • AUTOMATIC
CHANCE DANIEL
So I’ve been having issues with my wipers. The pump doesn’t work and I don’t have any variable speeds. Every now and then I’ll get it to wipe on high, but most cases it just does a single cycle. I have looked at the fuse diagram to see if it’s a relay or fuse but the diagram only shows the wiper motor fuse. I can’t seem to find the relay anywhere on the diagram.
May 26, 2021 at 4:01 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. The wiper motor relay is located in the under hood battery junction box. Here is a tutorial showing how to test a relay as well as electrical wiring:
I've attached a picture below showing the wiper motor relay location and circled in red. I've cut the wiper motor wiring diagram in 3 pieces so you can view larger. Let us know if you have any further questions on this issue. Hope this helps and thanks for using 2CarPros.
May 26, 2021 at 3:28 PM
