windshield wipers and radio
137,000 MILES
ENOCKER
a short while after starting the engine the windshield wippers and radio cut out
Apr 22, 2013 at 2:26 AM
HMAC300
  • 48,601 POSTS
check fuses first as they may have blown then check ground battery to body ground and radio to dash ground
Apr 22, 2013 at 2:32 AM
ENOCKER
when I turn the key the motor will not turn over Ihave no power any where lights ,wippers, windows,gauges, the battery and connections are good .all fuses are good, could this be a relay somewhere or what is my problem.
Apr 22, 2013 at 7:14 AM
HMAC300
  • 48,601 POSTS
check yoru ign fuse on rh side of dash it's 60 amp itcan also be a bad ignition switch.you can try reseting your security system but that won't cause wipers not to have power.you need to start at battery and see where power stops
Apr 22, 2013 at 8:00 AM
